TheBirkmeister
Computer
- Jul 21, 2010
- 3
I am trying to find out the feasibility of using a small 675cc propane engine (which runs a pump) to keep the v8 diesel engine on a delivery truck hot. The customer wants to find a way to keep the cab warm for the truck drivers in temperatures as cold as -25 degrees C. While making a delivery, which could last 30 minutes, the propane engine's coolant would transfer heat to the diesel engine's coolant. When the truck driver turns the truck back on after the delivery, he will get immediate access to hot air since the diesel engine is still warm.
The main concerns are whether the propane engine will produce enough heat and if approximate cost of installing this kind of system will be cost-efficient. Can anyone help me with the answers to these concerns?
