oompaloompa
- Jan 26, 2007
- 29
Hello everyone. I work for a small cooking equipment manufacturer. My background is in Mechanical Engineering so I thought I might ask you guys over here for some help. We have a customer wishing to heat a 70% Sorbitol solution(sugar substitute) to a temperature of 375 degrees F. Our largest cooker is cylindrical in shape, double-walled with exhaust near the top, product open to atmosphere, and has gas burners underneath capable of putting out 520,000 Btu/hr. We recently tested our unit with 110 gallons of Sorbitol in attempt to heat this product to the desired temp. We found the product temperature hovered around 220 degrees F for more than a few hours. We suspect that the water in the solution had to boil off before the product could reach the higher temps. We need to speed up this process, without pressurizing the unit. Our guess is that we need more surface area in the tank. Is this correct? If so, what type of physical features would you suggest we add to the tank i.e., fins, tubes, etc.
Thanks in advance for the help.
Michael
Michael
