Dear Engineers!
I would like to heat two copper tubes 1 meter long each to about 200 celsius degrees for a textile finishing application.
The tube's diameter is 35mm, thickness is 1,5mm and an electric heater 300mm long is placed inside the tube on one side or both.
As copper is a good heat conductor, do you think I will be able to maintain around 180 degrees celsius in the middle of the tubes?
