If I wanted to heat treat a shaft made from 4140 with the major O.D. @ 2.5"... what would be the ideal temp/amount of time and proper quenching method be?... My gears that I tested have a Rockwell of 62 on the "C" scale... So if anything I'd like to match the hardness or be a little under that of the gear...It'll need to handle decent torque loads (I know this isn't the best material to use, but it's all I had). I know I'll have to stress relieve or temper it to bring it down etc... Any thoughts Ideas wouod be highly appreciated...
Also, how much will this material expand after the heat treatment... And how would I compensate for this?
