I'm going to dissent from mfgenggear's recommendation. The cold working process will strain harden the tubing, but to what extent? Starting with annealed tubing, I don't think you have the first thing to worry about at 50 psi. I don't know what your wall thickness is, but calculate the burst pressure on your tubing and I'll bet you're looking at somewhere in the 10,000 psi neighborhood even with relatively moderate wall thickness. And even it it's not that thick, where would your burst be? 5,000 psi? 1,000 psi? Even at a ridiculously low 1,000 psi, you're looking at a 20:1 safety factor against burst.
So now you're wondering about how the cold working is going to affect the useage of the tubing. Remember that all of your ductility occurs between the yield strength and the ultimate strength. When you bend it -- once -- you will modify the yield strength, but you will not be changing the ultimate strength. Burst is calculated based on ultimate strength and not yield strength. So when you bend it, your ultimate is unchanged so your burst SF remains unchanged somewhere between 20:1 and 200:1.
But what about cyclic loading? Even after you have made the bend, you would have to determine if your stress is above the material's endurance limit at service temperature. If it is close, then you would probably be good to anneal it, but at 1,000F, I can't imagine there being a problem.
Now, it's time to talk about creep. If you're going to have a problem, I doubt it will be because you didn't anneal it. It will be because of the creep properties of metals at elevated temperatures. Even then, at the (I assume) very low stresses you're dealing with, I don't think it's going to be a problem. If you want to know more about high temperature creep, do some research on the internet. I would imagine that you're going to find that you're still just fine.
Here's some good reading on the subject of 304 from a steel supplier:
I vote to bend it and be done with it. If you're still worried, talk to your vendor.
Engineering is not the science behind building. It is the science behind not building.
