sailoday
A typical car heater/defroster blows hot air into the passenger compartment. The heating (and cooling in the summer) is done in the engine compartment. The two compartments are separate (usually by a metal wall). The piping for heating system does not directly interact with the passenger.
In so far as "providing constructive input on why an idea may not work," I obviously mistakingly thought that providing input as to the dangers and liabilities associated with having someone sit on a seat with a pipe under him/her and behind his/her legs holding 180°F - 196°F (82°C - 91°C) was sufficient. Perhaps my wording was a mite too terse to properly get the concept across that even a minor pinhole leak inside the passenger compartment could release that hot fluid directly onto the driver/passenger or that even a minute quanity of fluid at those temperatures might cause damage to human skin, much less distract the driver leading to an accident.
Furthermore, because it appears that the hot fluid piping would be encased in foam, there is a danger that the fluid might be adsorbed by the foam, depriving the engine of coolant while also causing the above-mentioned damage.
Additionally, because of the possibility of an automobile being involved in an accident, there is a danger of a coolant pipe being severed (especially due to sudden seat movement.) This could lead to a large quantity of extremely hot fluid being suddenly released unto the human occupants of the car. This could result in 2nd or 3rd degree burns.
I should also point out that, at least, the American Justice system has taken a dim view of manufacturer's whose products end up hurting people, especially when such hurt could be avoided through a reasonable design.
Finally, and to interject a somewhat humorous note: It's not my bottom that gets cold, it's my feet! Perhaps kmasine would do better to turn his inventive gaze onto a way of running all that engine coolant underneath the automobile to heat the underside and provide a warm floorboard.
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
