beavertail
Chemical
Caveat: this likely sounds like someone's first year homework but isn't.
I have a reactor venting hot saturated exhaust to downstream treatment and recovery processes. The exhaust requires cooling prior to treatment for reasons of moisture removal and equipment proteciton. I've been talking to my client in terms of vent condensors or some other appropriately specified H/X unit. They are asking me, in turn, why they can't simply educt sufficient ambient air into the exhaust stream (which is under a slight vacuum) such that the blended stream is adequately cooled.
My gut tells me this doesn't work too well, that gas-gas bulk HT will be very inefficient due to low k, poor mixing etc. It seems possible to demonstrate suitability just based on a heat balance but this neglects HT _rate_ and all the variables behind it.
30 textbooks and a long websearch later and I cannot find a relation or even a qualitative discussion of the effectiveness of direct mixing of two gases or how one may estimate the resultant blended temperature.
Any thoughts? Am I just really overcomplicating matters? Conversely, can I get there from here? I'm pretty far down the rabbit hole at this point.
thanks to all.
thanks to all.
