Hello Everyone,
I am trying to see if our current cooling system is capable of condensing styrene vapors from our reactor during sampling and charging styrene if we add another exchanger. We currently have a 50% propylene glycol solution going through the shell side of the 7 condensers on 7 reactors. We want to add one on an 8th reactor. I believe testing was done to see the mass flowrate of styrene during each of the conditions (charging and sampling). I can see from literature the cooling capacity of the chiller system (cools the glycol after it goes through the exchangers).
How can I check if adding another exchanger will be too much for our cooling system. The reactor is at ambient during charging and about 90C during sampling. Would I just need to calculate heat needed to be taken away to cool styrene to its boiling point then the heat of vaporization of the syrene vapor for one exchanger, times it by 8, then see if our chiller unit can handle cooling the glycol enough? Maybe also look at how adding the temperature changes in the glycol after heat transfer in the condensers?
Thanks.
Thanks.
