I need to remove the heat (approx. 800 watts) that is generated inside an industrial enclosure that contains a matrix (8 x 20 ) of cylindrical electronic packages mounted through one side panel of the enclosure. I must remove the heat by means of convection only. My initial approach is to force air axially through the matrix of electronic packages. The forced air would exit the enclosure through a series of holes no larger than 1/2" in diameter that are placed between each of the electronic packages. (I hope this is making sense !?!?)
I need help in determining the equations needed to calculate the requirements to remove this heat (Volumetric Flow, Exit hole size , number of holes, air velocity, etc.)
Any and all help would be greatly appreciated- equations,references,websites,etc.
ssmith
ssmith
