heat transfer coefficients
hungrychemE
Chemical
Sep 11, 2007
3
I am trying to calculate the rate of condensation of Propane vapor at night in a carbon steel pipe due to temp drop. Is there any link that would show me the heat transfer coefficient for the propane? I would also need the heat transfer coefficient for butane (same situation). In addition to this I would like to find out the convective heat transfer coefficient for light wind on carbon steel pipe.
Thanks alot
Ambient air on the outside and condensing hydrocarbons on the inside. Hmmmmmmm. I think the heat transfer coefficient on the outside will be controlling, so I suggest you shift your focus to that. A value for condensing HCs of 100-150 Btu/hr/ft"2/F seems reasonable, but it doesn't really matter because the htc of air on the outside will be an order of magnitude lower.
Good luck,
Latexman
Radiation+convection ht coefficients from horizontal black pipes depend on their temperature, diameter, and [Δ]T with their surroundings. Enhancing effects such as by wind or a clear sky at nights may increase these values.
Indicative values (Btu per hr.ft2.oF) for pipes at 80oF in rooms (still air) I took from one source:
[Δ]T, oF [→] 100 200 400
pipe dia., in.
4 2.2 2.7 4.0
8 2.1 2.6 3.9
12 2.0 2.5 3.8
