Hi!
We've been 'messing' around with a new micro reactor type device.
We're now wanting to estimate the heat transfer coefficients for the device.
It basically a straight etched channel in a sheet of 316L SS. The heat transfer occurs throgh the base of the channel to a utility stream passing underneath.
The problem we are having is defining the heat transfer area.
For example, lets say the sheet of steel is 5cm wide and 2cm thick. The channel is 2cm wide and 1.8cm deep.
The utility stream covers the whol of the underside of the sheet (i.e. is 5cm wide.)
What is the Heat transfer area?
Is it simply the width of the base of the channel (i.e. 2cm x its length)
It it the area the utility fluid touches/cools (i.e. 5cm x its length)
or
Is it the area of the base and walls of the channel? (i.e. 2cm x its length + 2*(1.8cm * its length)) (The top of the channel is 'blocked' with an insulating material.)
Or is it something else??!!
All thoughts, comments, references, anecdotes Greatly received!!
Also, when calculating Q (for the Q =U *A *LMTD) is it correct/OK to us Q = the average of the energy gained by the utility and lost by the porcess stream??
