We are welding 5/16" mild steel plate on the top of a helideck to the top of W12x 16 beams with the spacing in between the beams are approximately 32". The fillet weld used is a 3/16" ("according to spec."
and we are using GMAW-S to minimise heat input. We are experiencing the sheeting sagging up to 3/8" in between the beams.
What can be done to minimise this as well as fix these sagging areas?
Heat shrinkage is allowed but how is it done?
