danieldecko
I have a question regarding to Heat recovery steam generators. For ex. a HRSG with a two pressure level steam generator has some design parameters; such as pinch point and evaporator approach temperature for both sections. I would like to know if gas to steam temperature difference at superheater exit is also a design parameter? For ex. let's suppose that in a combined cycle, a gas turbine exhaust combustion products at 510 C. If we say, gas to steam temp. diff. at superheater exit is 32 C; steam turbine inlet temp. becomes 478 C. For ex., then we wanted to change the gas turbine and we want to put a gas turbine with 540 C exhaust temperature. So, if we fix the gas to steam temp. diff. at superheater exit, a desuperheater should be used after 1st stage of high pressure superheater to maintain the same steam turbine inlet temperature. However, if it is not a fixed parameter at the design point of HRSG, only the amount of steam produced in high pressure drum will be changed.
In conclusion, I would like to ask whether gas to steam temp. diff. at superheater exit is a fixed parameter at design stage or not? Or, If any source could be supplied related to HRSG design, I would be grateful. Thanks...
