I am having problems sizing relief valves for HC mixtures(C1 to C8). I've looked at it three ways and can get no agreement from the senior staff.
Method One: Choose the heat of vaporization for the mixture as reported by HYSYS. This HoV is essentially an average required to vaporize the entire mass and typically runs in the range of 200 to 500 BTU/lb.
Method Two: Perform fractional flashes and calculate the HoV based on the heat required to vaporize the material. This method includes the sensible heat. Initial vapor commonly has an HoV greater than 2000 BTU/lb. In no case have I seen an HoV less than the average reported by HYSYS.
Method Three: Look at the predominant component and choose that HoV. These values typically have a value of 50 to 150 BTU/lb.
I am inclined to use Method Two since API RP 521 3.15.3.1 and Appendix A.3 support this method. But method 1 is attractive for its ease of use.
Any suggestions?
Any suggestions?
