I am trying to determine the heat loss from a 2-1/2" schedule 80 CPVC pipe that is carrying a 27 deg F solution of 30% propylene glycol. The pipe is inside a 70 deg F plant.
I found a similar thread (thread391-289057) but it's focus was on buried pipe and no mention of glycol. I have seen the formulas where the heat loss is calculated based on pipe surface temperature, ambient temperature, wind speed, etc
In my case I don't know the surface temp, just the fluid temp inside. It's probably fair to assume zero wind, since we are inside the plant.
Can anyone point me to a reference or provide a formula?
