Dear All,
I am a student of Welding. I couldn’t understand the reason for the below statement.
“For high heat input the cooling rate is low and for low heat input the cooling rate is high.”
As far as I know the rate of cooling depends on the temperature difference. High heat input should result in high temperature than low heat input and the temp differential should be high in high heat input. Hence the cooling rate should be high in high heat input case.
