mmmumuw
- Sep 22, 2003
- 27
Perhaps I missed this class while in college ...
I understand that the actual pumping capacity (and head) is the result of intersection between pump curve and system curve.
there is a pump supplying cold water for a typical heat exchanger process (cooling). By the ampere meter reading, we can point the flow at 5-10% in the left of BEP. It is 50% valve closed.
I can get why after we open the valve fully, the pressure get raised (4 bar fro 3.5 bar).
Has it got something to do with Heat exchanger system curve behaviour? Can you engineers explain, please...
Many Ths,
MW
Many Ths,
MW
