I am looking for some simple equations or rules of thumb for determining the straight length of tubing required to acheive a desired amount of heat transfer. The tubing would be formed into a coil. The coil would be immeresed in both still or agitiated water.
I would like to analyze both single phase and two phase flow. The two phase analysis would be used to make low cost evaporators.
The knowns are evap. temp, water final and initial temp, cooling medium mass flow rate, and tubing diameter.
In a nutshell:
"I want to make a 2 ton evaporator out of 1/2" coppper tubing in a tank of water. I am using R22, need 60 deg F water, and the water in the tank is not moving. What is the total length of tubing required"
Thanks,
Jeff Johnson
In a nutshell:
Thanks,
Jeff Johnson
