khanlon
- May 13, 2006
- 1
I'm currently investigating the replacement of a steam boiler with localized hot water systems to supply heat to mixing vessels.
I can find the heat transfer coefficient of the current steam set-up but need to determine what would occur if water instead of steam was used as the heating medium. Specifications on the actual mixers is fairly limited.
I was going to use;
Q=m(h1-h2)for steam and equate it to water i.e. Q=m(h1-h2)(for current steam)=mCp(LMTD) (for proposed hot water system)however this leaves me with two unknowns m and LMTD.
Any advise on such matters would be greatly appreciated.
I was going to use;
