Good Evening,
I am currently desiging a heat exchanger to heat Air from 10 oC to 110oC and cool flue gas from 1259.4 oC to 725 oC.
As both fluids are gases, i would like to know if it is advicable to use a shell and tube heat exchanger?
I read online that the convertional gas-to-gas heat exchanger is vertical shell and tube heat exchanger
Thank You Very Much
Kind Regards
Paul
Thank You Very Much
Kind Regards
Paul
