I have a question..In a process of hot bonding two similar metals together
and cooling it to a room temp quickly from 1000 F directly out of the
rolling mill. I have been asked to cool the metal slowly not with such a shock and with no contact of liquid.The only way that I can think that this could be done is to have a hollow roller with a rotary coupling feeding fresh cold water and having the metal ride over it. The diameter would have to be large I imagine and as much contact surface as possible.
The material is .180 thick and 4" wide at 10 FPM.The end result would be a temp, that man handle without being burned.
What is the formula for heat exchange for this type of application?
Any help would be great.
Thanks.
Thanks.
