ron9876
- Nov 15, 2005
- 669
If you use a steel plate with multiple headed studs embedded in the top of a bond beam how do you determine the shear capacity perpendicular to the wall. ACI 530 gives a formula that appears to be intended for a single anchor. Surely if more studs are added then the capacity would go up.
