tomecki
- Aug 18, 2014
- 18
I'm working on an a 36" DR9 HDPE pipeline to carry warm (30 deg C) water. The pressure rating of the pipe is sufficient at 30 degrees, however I'm concerned about further heating of the pipe due to solar radiation. The Plastic Pipe Institute HDPE handbook says that the surface temperature of black HDPE pipe can get up to 65 deg C in the sun but doesn't go into much more detail.
At an average pipe wall temperature of 47.5 deg C the pipe fails. I hoped that due to the low thermal conductivity of PE, I could show that heat doesn't penetrate fast enough to heat up a significant portion of the wall thickness during the day. My calculations show that it does. I also hoped that the fact that only the portion of the pipe directly facing the sun would get that hot would help, but it doesn't seem to. The location of the project is far in the north, so the sun won't be directly overhead even during the summer, but applying Stefan-Boltzman law for the expected solar radiation and an emissivity of 0.95 gives me an even higher surface temperature than 65 degrees.
I'm wondering if anyone has any experience with something like this, or can point me to some design references that would help me analyze this problem better.
Perhaps the pipe isn't suitable for the application in which case I wonder if there is a simple way of protecting the pipe from the heat.
