HASCO NX REUSE LIBRARY
jonnythefox
Industrial
IE
Hello ,
I have a question regarding the New Hasco Reuse Library.
When I save an assembly file with a configurable Hasco part file from the reuse library it overwrites the itself to the saved configuration.Any other assemblies that use the same part will now have the same part file configuration.
I have tried editing the KRX file and used the "family member save" directory to save a different location. It does not seem to work. It always overwrites the part file in the reuse library.
The other reuse libraries I use do not behave like this. When I save the file it creates a part family member in a specified directory.
I have tried using the reuse Hasco Reuse Library in NX 10/11/12 . They all behave the same way for me.
Is there something I am overlooking?
Thanks for you help.
Hello Jonny are you adding it as a reference or clone ?
NX8.5 - NX9 - NX 10 - NX11 - NX12
BETA TESTER: 11 - 12
We recommend using cloning the parts into your assembly. With that you can modify each ejector for example to your desired length.
with kind regards
Daniel Dirksen
HASCO
CAD Services
cad@hasco.com
I would like to propose this.
add a line to the krx file of the parts that you always want to have cloned:
<RenameOption>Clone</RenameOption>
This forces to use clone in stead of reference.
more on this:
Link
Kind regards,
Pascal
