At my company, we recieve customer prints, then create internal process sheets for routing the parts from raw stock to the finished part. There are sometimes 20 different sizes of a given part. I create the models using a design table. That is the easy part. The bad thing is my employer requires a seperate "process sheet" (slddwg) for each individual size, meaning I can't just make one drawing sheet with letter tags and a table showing the dimensions that change.
So currently, I create all the process sheets for a given part, then copy those files to the folder for the next size, then go into each drawing file, right click on each view and change the configuration to the next part, as well as updating the title block info.
Any ideas on streamlining this ?
