Hi Gents,
I came across an issue with hardness value variation on the 4130 round bars. The details are as follow:
Material: AISI 4130 Round bar, Heat treament condition: Quenched & tempered, Hardness tester used: Brinnel, Hardness values mmeasured: 283-312 BHN, Acceptable limit as per API 6A: 197-235 BHN.
Now our contractor has come up with following statement:
Hardness readings taken previously were not accurate since material was exposed to environmental aging and hence, surface hardness found more.
Now, they had skim the face of raw material and conducted hardness test again and harness values are coming within the acceptable range of API 6A.
Can we accept this variation in hardness before and after surface skimming(slight machining)? Please advise.
