mforoutanfar
Hi everyone,
We're having a problem with an incoloy 800 part overlaid with stellite 6.
The part is a thermowell shaped roughly like a drilled partial cone with large diameter of 28mm, small diameter of 20mm, height of 90mm and drill diameter of 10 mm. The overlay thickness is 2mm and has been carried out by manual welding. (The original thickness was more than 2mm, the extra thickness has been machined)
After carrying out a hardness test on the finished part, it turned out that the surface hardness decreases drastically (from 436 HB to 182 HB) as you get closer to the small diameter. The required hardness is between 300 and 400 HB.
Now here are the questions:
- Why does the hardness differ in different points? Where did we go wrong?
- Can the hardness be restored in any way without machining and overlaying the part all over again? (e.g. some kind of heat treatment, etc.)
Thanks!
Thanks!
