Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
This depends on the specific oil you are using. The chemistry you quoted is not very hardenable, so you will need the temperature recommended by the oil manufacturer that will give the fastest quenching rate. The people who sold you the oil should be able to help here.how much quench oil temperature and how much quench delay should be
A cooling rate that would produce 50% ferrite, 50% pearlite with an as-quenched hardness of 95 HRB (215 DPH) will get your from 845C to 100C in two minutes. Since this is unacceptable, two minutes in the quench should be sufficient. I like overkill on quenching, so you could consider 10 minutes in the oil. It wouldn't hurt and would make sure the quench time is not your problem. If you need to shorten it to maintain the cycle time for furnace, that should be OK, but I wouldn't want to go less than 5 minutes.how much quench tank time should be for sufficient duration
From the diagram, a mixture of 10% ferrite 90% pearlite would give you an an-quenched hardness of 21 HRC (242 DPH). 10% ferrite and the other 90% a mixture of bainite and pearlite would be 28 HRC (284 DPH). I'd assume DPH is 10KG Vickers. This tells me that you should be aiming for around 28 HRC as-quenched.how much quench hardness should be.it should be higher side for less ferrite
Does it mean the customer requirement for UTS is 830 N/mm2 but you only achieve 730 N/mm2 for UTS?customer told that 730 N/mm2 UTS Pc break and 830 N/mm2 pc not break.
