Hard chromizing of stainless steel ball valve
Mighty
PLease advise whether it is necessary to provide hard chromizing of stainless steel ball valves.
Thanks in advance.
Mighty,
Depends on the application!
Hard Chrome Plating is common in ball valves for corrosion resistance. If you have a abrasive or scaling media look into nickel alloy overlay rather than chrome.
Mighty,
Hard chrome plating stainless steel balls increases the wear resistance only. Since chrome plating contains small cracks that extend down to the base metal, it does not increase corrosion resistance.
BCD
BCD,
I AGREE!
I forgot that mighty said stainless steel ball!
It is often a common practice to do Electroless Nickel Plating of Balls for superios performance.
