Hall Effect Sensors: Differential vs. TPOS??
Travman1023
3
Can someone explain the differences between a differential hall effect sensor and a TPOS (True Power On Signal) hall effect sensor? Are there any physical construction differences? Or mainly just different circuitry and programming?
I am starting to reverse engineer camshaft and crankshaft sensors and this question has been coming up frequently.
Thank you.
To my knowledge, differential measurements in other applications use some analog method of measuring noise, separate from the raw signal.
The noise signal can be channeled through a shielded wire, into a comparator-- or something with similar capability.
The raw signal is then channeled into another terminal on that same comparator/op amp.
Something mysterious happens within that circuitry, and the difference between the noise channel and the main channel is what gets amplified.
The differential is basically comparing 2 different values, and operates based on the difference of those two values.
Take this info cautiously. I'm no expert. Just trying to help establish clues for you that may help
