dakota99
- Feb 23, 2005
- 21
I am working under the 2002 masonry code using allowable stress method. I am looking for limitations on height to thickness ratios for hollow concrete masonry with load bearing walls. I have always designed cmu walls with an h/t> 30 as slender walls. h being the height of unbraced wall and t is the thickness of block i.e. t=7.625 for 8"cmu block. Are there any other restrictions on h/t for walls? also does anybody ever use the equivalent solid thickness as t?
