Does HSS - Hollow Structural Section refer to both square and round sections?
What material specification shall I use?
In the past I have specified ASTM/A500B for structural square tube. And I have referred to it on structural framing plans as TS4x4x5/16. Apparently, I should specify HSS4x4x5/16.
For structural round pipe I have never given an ASTM spec.
And I have referred to it as P5STD, XS or DXS. How do I specify round HSS? Should I be specifying ASTM/A53?
What current specifications should I be using?
Thank you!
Thank you!
