We have a tank where one or more different chemicals are charged, mixed, and then fed to the reactors. After the last addition and before mixing, we currently flush the line to the tank with water to get all the active ingredients into the tank.
We want to stop using flush water and use nitrogen to blow the ingredients into the tank.
All the two phase flow information I have found so far deals with continuous flows of liquid and a continuous flow of gas, L/G is fixed. What we will have is a dynamic situation where the quantity of liquid decreases (full pipe to empty pipe) over time. I suspect the resistance to flow of the nitrogen will vary also, from liquid to two phase to gas flow.
I've done a little thinking on how to design this, but I figured someone else has probably done this before, maybe many times before, so . . . does anyone have a good reference, guidelines, or advice on this?
Thanking you in advance for any help you can give me!
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
Good luck,
Latexman
