If the nuts and bolts are galvanized, should the threads on the nut or the threads on the bolt be tapped?
I remember reading that the female threads on the nuts should be tapped after hot-dipping such that all the zinc coating is removed from the thread. If so, would it still be necessary to tap the coating on the male threads of the bolts?
By the way, a Simpsons rep told me zinc coating and galvanizing is two different things. Can somebody tell me the difference? Which would you use for bolts and nuts?
Thanks,
Thanks,
