I have an old machine that employs a guide pin machined from 8620 steel that is case hardened to 50-60 Hrc that has been galling against a sleeve of 4140 hardened to 35-40 hrc. This is a recent occurance, and my research indicates that the carburizing process used to harden the shell may not be the best candidate here.
Should I consider using a different material altogether for the guide pin, or perhaps look at another heat treating process like nitriding or coating with something like titanium nitride?
I appreciate your advice!
