GRP Piping Seismic deign
KevinNZ
850
Hi all
We are design buried and above ground GRP piping. Design code ISO 14692. The code covers allowable stress for occasional loading conditions.
The question is, what ductility/performance factor/response factor etc to we apply when working out the seismic design actions? would it be more or less than carbon steel piping?
Attached are some references I have for GRP/FRP piping design. It has been years since I did actual calculations using Caesar so I forgot most of how I performed them, but the attached may help.
  • DesignEnvelope.pdf
  • FRPdesign.pdf
  • LoadingConditions.pdf
  • dec97.pdf
GRP tends to hate stress loading and has in my experience very limited ability to be ductile or accept any excess forces or stresses, especially point loads or stress concentrations. The pipe joint areas in particular are often non homogeneous and result in significant stress concentration due the changes in thickness at many of the joiint design.
I would be very careful here and look closely at what snickster has provided.
Personally I would never now bury GRP unless it is straight level lines inside a plant. Good in its right place, but can e very tricky outside of that. Just my experience.
