Canwesteng:
But, being general and misleading or incomplete, is no good for anyone. You gotta give all the needed info. to really start to solve the problem, to the best of your knowledge. Some of you guys have a way of making your questions so damn general that nobody can make a meaningful judgement about what you are trying to do, or the magnitude of things. It was a column, now it’s a W10, which you better have web stiffeners on at the bearing pl., so it can’t roll over. What are the various loads, vert., along the beam and perpendicular to the beam, and from what? What’s atop the W10, show a sketch? You probably have to guide the movement, or it can move any which way, and you may not want that. You need to cover and protect the slide surfaces so they don’t get full of junk over the years, and you have to cover any slotted holes for the same reason. If the slotted holes fill with rust or some such, they will bind-up. In terms of bracing and thermal movement, why is this bldg. different than any other long steel bldg.? What’s really going on at this bearing pier? We don’t normally provide sliding bearings.
