Hi, everyone.
It is measured that the earth resistance for a particular grounding is more than 20 ohm.In fact,the earth resistance is required to be less than 5 ohm.Instead of planting a new earth chamber into it, it is any other solution to lower down the earth resistance?Is it a practical way that bonding the copper tape all around with other grounding?But ll it give a steeve decreasing from 20 ohm until less than 5 ohm?
