Make dam sure that the fluids used are compatible with the materials involve. Depending on the end use of material to be ground.
Over the years I have been bitten by changing the dialectic of the material, incompatible residues left on the surfaces, moisture up take in the material etc. etc. You need to understand what the intended end use is and what both the expressed and inferred specifications are..
Good luck -- the devil is often in the details
