Green Book turning templates
vmirat80
7
It is my understanding that the turning templates in the AASHTO Green Book assume that the vehicle is starting the turn with it's wheels already turned to max angle. This doesn't seem to be a realistic condition. The turning path of the vehicle will be affected by the time it takes the driver to turn the steering wheel. Is my understanding of the templates incorrect?
I believe you're correct; the templates as drawn have an immediate transition from tangent to radial at the point of curvature. To mimic real life, there should be some distance (time) for the driver to crank the steering wheel, unless vehicle is at a dead stop before turning. These templates are for low speed maneuvers, and the small transition from straight wheels to full turn not shown is probably not significant.
