1
- #1
RichardSteinburg
New to this website. Hello to all.
I've recently been given the task of recommending the rate of grease flow for the bearings of a jaw crusher in a nickel mine. The crusher unit will have new grease injection points put into the pitman arm and main shaft bearing caps to supply grease.
Before I get into specifics, I'm just wondering if anyone knows a good resource for determining grease flow into a babbitt bearing.
So far I've seen that most babbitt bearings are oil lubricated, and I have heard that determining grease flow/injection rates can be a trial and error process.
Some factors that might come into play are:
rotational speed
type of grease
bearing clearances
Thanks in advance for any help.
Rich
rotational speed
type of grease
bearing clearances
Rich
