Rig_man_31
Petroleum
Hi pipe gurus,
Hydraulics is not my area of work but I have a problem my company has been experiencing.
We deposit multiple slurry streams into a drop box where it then travels by gravity for 4 miles.
We find that the drop box is overflowing quite often.
Along the line there are three pressure transmitters. At mile 0.9, 1.8 and 3.
The pressure transmitters at 0.9 and 1.8 read a vacuum of about -8 psi. Mile 3 reads positive pressure, but nowhere near pipeline pressure rating. We will observe backing up of the drop box followed by a spike a few minutes later in pressure at Mile 3. The drop box level will decrease and then Mile 3 will be decrease also with a few minute lag time.
If downstream transmitters are under vacuum is that an indication it is under slack flow conditions in those areas and the bottleneck is upstream?
In between the inlet and Mile 0.9, is there is a bottleneck? The inlet doesn't have fantastic grade. About -1.5% to 2% for the first 0.2 miles.
The drop box discharge line is buried deep and there isn't really an option to upsize the line. However, we could direct some of the slurry streams further down the line (line grade is about 6% here) and reconnect where the pressure transmitters are reading a vacuum. As my understanding was that in slack flow conditions the pipe is not full and their should be excess capacity there.
