Mike4chemic
Chemical
Hello all
I have a question regarding design of pipes for gravity flow and self-venting flow regime.
There is a steam condenser (not a direct contact. A shell and tube ) ,which its condensate flowing from the bottom of the condenser head and to a condensate tank downwards.
At that condensate tank, a vertical pump will be installed, and also a level transmitter
I wish to avoid adding another level transmitter at the condenser head bottom, and to be sure that no condensate is accumulated there (so it won’t flood the tubes and reduce heat exchanging efficiency).
My question is: how important is it to design the condensate pipes from the condenser to the tank to be self-vented ( meaning :Fr<0.3 ) ? (To me it will dictate a difference between a 4/6” line to a 10” line )
A few figures ( See also an attached schem ) :
The elevation differences between bottom of condenser head to top of tank : 6.5 ft
The pipe length including equivalent length for valves and fittings: 50 ft
The expected condensate flow: 300-350 GPM
The tank will have a vapor equalization line between it and the condenser head.
The pipe will be slightly submerged in the tank liquid ( to avoid steam escaping )
I have read threads : 378-136655, and others, but I still debate with this issue .
I will appreciate your comments
