Engineerboards was just started within the last two months as a spinoff from a site frequented by engineers regarding the PE test. Its a discussion board in its infancy. I am hoping that it gets more into other things aside from the PE test eventually.
Nice that you are running your own busininess.
My problem is probably seriously trivial for someone like you, but here it is.
Here is the latest and greatest:
-Diesel
-Liquid height will vary from 17.75 (tank full) feet down to 7.5 (tank empty) feet. Likely it will often be somewhere in the middle. In fact, It may never get to the max or the min listed here.
-Total pipeline from tank to engines is about 134' to the longest run.
-Total fittings: 8 ells, 1 full port ball valve, 1 emergency shutoff valve, 1 union and one SS expansion joint.
That's about it.
I also have to size a similar one with less flow and slightly different routing.
I'm mainly hoping someon can push me onto the right track to figure this out. I'll be glad to hear any feedback you may have.
Ed
