Hello everybody.
After looking on grating shopdrawings and shopdwgs of the structural frame was discovered that there are some cases when grating panels are without any support. I've decided to weld 50x6mm plates to the upper beam flange(HEB320 HEA200) as shown on attached sketch for support parts of the panel that was without some support.
Please tell me if you have any doubt about this solution(plates have already been welded).
The panels should carry uniformly ditributed load 5 kN/sqm.
Thank you
Thank you
