You can use a rubberized epoxy in order to increase flexibility and impact resistance. We have used Dow DER 736, a low viscosity epoxy diluted with glycol. Depending on your process, there is also the DOW XZ product line, a high viscous resin, and the Sikadur products form Sika. I will also suggest replacing the carbon fiber for a thin woven glass, it will perform much better on this application. If you care about the esthetic finish, you may also try basalt fibers.
