graphic problem ACAD2000i 2
ZoranB
RS
I'm using Acad 2000i under WIN2000.
Since I don't know the right termin for the problem i'll try to explain it.
when, for example, i draw a rectangle, after pointing at first corner point i dont get a visual aid while moving crosshair (there is no variable coursor-position-depending rectangle since the other corner point is defined). After defining other corner the rectangle is drawn correctly.
The same things happens during copy or move commands etc.
I guess there must be some problem with graphic card (MSI MX200) since the problems started after installing it. I tried several different drivers but problem stays.
Anyone had a similar problem? Any solutions?
thanx
Hi
Looks like a syste variable setting.
Command: _dragmode
If it is zero, set to 2;
If it is off, set to "on"
Hope this helps.
thanx for a fast answer but...
unfortunately, the problem stays on even dragmode variable was off.
sorry to hear that
dragmode is to be made "on" and its value to be made 2
Please try again
Hey, you were right.
The DRAGMODE variable should be set to "Auto" (I guess it is 2 value).
Have you got an idea what changed it to zero (not me)?
thanx again
Well done.
Made me real happy.
No idea why sometimes dwg settings change. Autocad is not matured yet, I guess, but it is getting there.
Take care
