PAstructural08
I am design multiple grade beams running between spreadfooters. The spreadfooters are for building columns which are isolated from the mat foundation that I am also design. So the spreadfooters and grade beams are the perimeter of the mat.
The spreadfooters go below the frost depth (2m) and the grade beams are just in place for the mat foundation, obvioulsy I can't make the mat 2m thick for the frost depth.
My question is should I apply the at-rest pressure to both sides of the grade beam, or apply at-rest pressure on one side and active or passive on the other side??
Thank you
Thank you
