alanisphoenix
which is the usual heat treatment for the grade 3?
i'm doing some tests with the samples normalized and tempering, but the impact test values at -101ºC, are quite low (about 5 to 12 j)
Any idea to increase this values? Maybe adding more Nickel to the steel? the Ni on the heat is quite close to the minimum requested by the norm.
thank you
thank you
