Gone transparent
dj4244
48
Don't know what I did or what to do. All of a suddend my model is transparent (somewhat like a wireframe). I've pused all the screen buttons even gone out of model and back in no help.
David A. Johnson
Thunder Systems Inc.
Corona, CA
'splain yourself dj4244
What do you mean by "transparent (somewhat like a wireframe)."
I assume it appears to have some colouring to it & also that by "screen buttons" you mean the View Toolbar icons. If so, RMB on the part & click Properties > Advanced and check your Transparency settings. I don't know how or why it would suddenly change, but it's worth a look.
[cheers]
CorBlimeyLimey, Barrie, Ontario.
[bigsmile] Sign on a Barrie restaurant reads, "We serve Molsons, but we only smoke Ribs" [bigsmile]
faq559-863
I sounds like you are working on an assy. If so are you editing one of your parts? That will make the rest of your model appear transparent.
If your in an assembly and your editing a part, there is an option the Tools\Options\System options\Display/Selection - Look under "Assembly transparency for incontext edit" If you change that "Opaque assembly" your parts won't go transparent.
Scott Baugh, CSWP [borg2]
faq731-376
dj4244
Did any of the above work?
[cheers]
faq559-863
I inadvertantly entered edit mode on one of the parts in my Assy. What's an easy way to get out of that.
David A. Johnson
Corona, CA
Right click in the middle of the graphics window and choose Edit Assembly.
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
A hobbit's lifestyle sounds rather pleasant...... it's the hairy feet that turn me off.
